Any experts in Ruby Class out there?
Hello all, and thanks in advance for any help! I've been trying to set up a Ruby Class that can handle and use its own internal arrays. I'm quite a novice at Ruby classes, and the nearest I've got is this:
class Destination
attr_accessor :l
@@letters
def initialize(l)
@l=l
### # out if clauses on first run...
@@letters=[] if @@letters==nil
def name
@@letters.collect{|ch| ch[0]}.join
def addLet(l)
@@letters << l
def wipe
@@letters.clear
I need in the class an array, @@letters (I'll eventually need other ones too). Line 3 sets up a variable called @@letters. LIne 7 turns it into an empty array. The ... if @@letters==nil... is to keep already inserted members of the array, but without line 3 it throws up an "uninitialised class variable" error - I have to run the class with the if statement #'ed out first time. Once that's done it works!
With the class now running I can do things like
@ylist=Destination.new("") a new instance of a Destination
%w[W A S H I N G T O N].each{|l| @ylist.addLet(l)} ... each letter becomes a member of @@letters
@ylist.name produces 'WASHINGTON'
It needs to be individual letters because I want to set up and access other data related to each letter. I'm sure there must be a better way to handle this, but so far it's eluded me.
class Destination
attr_accessor :l
@@letters
def initialize(l)
@l=l
def name
def addLet(l)
@@letters << l
def wipe
@@letters.clear
- TimC
Re: Any experts in Ruby Class out there?
You're using a class variable, not a class instance variable. Class variables also need to be initialized when created.
A class variable is shared among all classes and subclasses, even its own class construction. Try doubling your code:
Here's a general rule of validity (copy and paste to a RubyEdit):
@ylist.name # 'WASHINGTON'
@ylist.name # 'WASHINGTONWASHINGTON'
class Parent
@@shared_among_everything = "class "
@shared_among_parent = "parent"
def self.shared_among_everything
def self.shared_among_parent
def initialize(name)
@specific_to_this_instance = name
def specific_to_this_instance
class Child < Parent
show = []
show << Parent.class_variables
show << Parent.shared_among_everything
show << Parent.instance_variables
show << Parent.shared_among_parent
bob = Parent.new("Bob")
show << bob.instance_variables
show << bob.specific_to_this_instance
show << bob.shared_among_everything
show << bob.shared_among_parent
bobby = Child.new("Bobby")
show << bobby.instance_variables
show << bobby.specific_to_this_instance
show << bobby.shared_among_everything
show << bobby.shared_among_parent
watch "overview", show.flatten
