SM prims can be used can't be added to FS toolbox
Postby tester » Sat Apr 27, 2013 4:27 pm
Here is a strange situation. There are primitives from synthmaker, that can be used in flowstone, but you can't add them to the toolbox. Are there more like these?
BTW, can somebody make a schematic with modules, that are in SM, but were not added to FS?
prims.fsm
(217 Bytes) Downloaded 1038 times
Re: SM prims can be used can't be added to FS toolbox
Postby MyCo » Sat Apr 27, 2013 6:11 pm
You can't add primitives to the toolbox (regardless where they are from). If you want to add them, put them into a module and add the module to the toolbox
MyCo
Postby tester » Sat Apr 27, 2013 7:41 pm
I see, my mistake.
Are there more prims missing in FS?
Postby RJHollins » Sat Apr 27, 2013 9:19 pm
Over at the SM forum, it was posted, ...
by malc on Thu Sep 20, 2012 3:37 pm
3. There won't be any automatic migration. You'll need to manually move the .hom files or put your modules in a schematic, load them into FS and drag them to the toolbox. It *shouldn't* be too much work.
Does this work manually moving the .hom files ?
Postby MyCo » Sun Apr 28, 2013 1:19 am
tester wrote:I see, my mistake.
I don't know... Since I work with it, the only primitive that I've missed was the FFT-Window that you mentioned.
RJHollins wrote:Does this work manually moving the .hom files ?
Yes it works, but don't know if they are getting the right Tags in FS. But when I need to port something from SM to FS, I just open a SM Schematic and copy the parts that I need.
MyCo
