BUG - You found a bug? Post here.
Postby Tronic » Thu May 09, 2013 6:26 am
Bug Green:
Primitive:
Float - always reset to 0 when dragged.
Less Then or Equal - It has the function inverted whit normal Less Then
Tronic
Re: BUG - You found a bug? Post here.
Postby Drnkhobo » Sat May 11, 2013 8:12 pm
Found a bug. . .
Whenever you have bitmaps loaded via Ruby (Stock Bitmap module) & in one of your Ruby module's you run into excessive processing, it shuts off ALL Ruby modules. So you save the schm to check this out further .
When you load it, all the "bitmap Rubies" are off. Switch em on again & they have errors. . . Nil.
You have to load the bitmap again into it for it to work correctly.
Maybe it was because I saved it while the modules were off but it shouldnt clear the bitmap file "cache" too . . .
Drnkhobo
Re: BUG - Huge use amount memory when navigate in toolbox
Postby Tronic » Tue Jun 11, 2013 5:06 pm
Huge use amount of ram when navigate with the toolbox tab,
the memory does not seem to be released, but always added, even after a long period of inactivity.
Tronic
