Audio click/pop using selector & filters
Postby Drnkhobo » Sun May 26, 2013 2:14 pm
Hey all, I have noticed a click in the audio when using a selector with a filter. The selector chooses the filters 'pole' which in my case is another filter. . . .
6dB = one filter
12dB = two filters (serial)
ect
so I understand that when the selector changes to either stream there will be a difference in the audio (naturally from the second filter) but how can I get around this?
I have thought about using a counter to trigger when the selectors index changes. This counter multiplys the stream from 0-1 so when you change the pole, it ramps up the audio from 0-1. but then the audio will drop when I ramp it up!
lol, I dont know if anyone has a work around? or if I have missed something?
Have a look at a quick fsm:
poleswitch.fsm
(10.98 KiB) Downloaded 1058 times
Has anyone used a pole select in their projects? Did you use a selector like this?
Drnkhobo
Re: Audio click/pop using selector & filters
Postby Morph » Sun May 26, 2013 2:53 pm
Hi
The selector recompile the schematic on change, so use multiply instead should work.
poleswitchmul.fsm
(11.48 KiB) Downloaded 1075 times
If it still pop, use de-zip between green and stream.
Morph
Postby Drnkhobo » Sun May 26, 2013 4:17 pm
Nice work around Morph! Thanks mate ;)
Dont know why I never thought to multiply the streams beforehand!
Just saw in the RBJ filter dsp module a line like this
stage(0)
  abs = 3.4e38|0.999999|0.1;
Anyone know what the "|" is for???
Drnkhobo
Postby Morph » Sun May 26, 2013 4:53 pm
Drnkhobo wrote:Anyone know what the "|" is for???
"Or".
Morph
Postby Nubeat7 » Sun May 26, 2013 5:00 pm
one of the things which is not to find in the user guide!
Postby Drnkhobo » Sun May 26, 2013 6:07 pm
Guys, i dont understand that . . . :oops:
the code is telling me that abs is equal to: 3.4e38|0.999999|0.1
so where does the OR operator compare? And to what? BOOL?
I know that the purpose of this line is to assign abs a value of either one of those but i dont get how its doing it.
I have/had the understanding that the OR compares two values & outputs 0/1 depending on if any are true . . .
Hang on, is this actually saying that abs equals 1 if 3.4e38 or 0.999999 or 0.1 ????
Drnkhobo
Postby trogluddite » Sun May 26, 2013 8:32 pm
It is float number voodoo black magic! ;)
The result of the OR line is a special value used for creating an ABS function elsewhere in the code...
Drnkhobo wrote:I have/had the understanding that the OR compares two values & outputs 0/1 depending on if any are true . . .
That's basically right, but in code (not 'green'), AND and OR work along the bits in each number, and'ing and or'ing things one bit at a time - so bit 0 of the output comes from bit 0 of each input value, and so on...
When you do a comparison in code, the result is a value with either ALL of the bits on (true), or ALL of the bits OFF false) - different than the simple 0/1 of 'green'. And that gives us the familiar behaviour of comparisons in code, where "TRUE & x = x" and "FALSE & x = 0".
However if you start AND'ing and OR'ing other number combinations, things get a little more, erm, "interesting"...
A float number has 32bits (well, not always, but it does in FS) - and the very last of them is the sign-bit that says whether a number is positive or negative - when that bit is ON, the number is negative.
So to get the ABS of a float number, you could just make sure that the sign bit is off - the other bits would stay the same, and abracadabra, we would always have a positive number. Hmm, but how?
Well, there is a way using a bitmask - you just need a number with all of the bits set to ON except for the sign-bit. You then do an AND (&) operation (which works one bit at a time), to get a result something like this...
0 1111111111111111111111111111111 (Special bitmask)
AND
1 xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx (A negative number because the sign bit is ON)
EQUALS
0 xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx (the same number but positive)
And somewhere in your code, i bet you will find exactly that... "answer = some_value & abs".
But there's a problem here; the bit 'pattern' in that special bitmask doesn't actually represent any particular float number that you could just write down in code - if you send 'abs' to a stream out and look at it with a readout, it will say "#.QNAN", the error message for "Not A Number".
However, like the AND '&' operator, the OR '|' also works one bit at a time - and by OR'ing those particular three numbers together, you can create exactly the bit pattern that you need for the ABS bitmask.
I first saw that very early on in my SM days, and I have no idea who worked it out - but it is a mighty fine bit of hacking, because doing "& abs" takes way less CPU than the usual ways of making an ABS() function.
Postby Drnkhobo » Mon May 27, 2013 8:05 pm
:o
Thanks a million Trog, you do know your stuff! LOL experience I guess!
Its still quite tricky!
out = ((out&abs) > 1e-11)&out;
there's that & !!!!!
Its quite a clever trick :D
Drnkhobo
Postby MyCo » Mon May 27, 2013 8:50 pm
FIY a shorter version for the abs hack:
stage(0)
  abs = 2|1.9999999;
MyCo
