Simple Ruby problem
Simple Ruby problem
Postby billv » Wed May 29, 2013 7:44 am
I'm having a go at turning my green counting systems over to ruby,
but stuck with a some real simple logic.
def event i,v,t
if v = 1 then output 0,t
This code gets me a trigger on each count.....???
I know I'm probably still thinking "Visual basic".... but i just don't get it :? .
If the value is =1 then give me a trigger.....seems a very straightforward instruction....
What am i missing here.....
billv
Re: Simple Ruby problem
Postby stw » Wed May 29, 2013 8:36 am
"==" not "="
stw
Postby Nubeat7 » Wed May 29, 2013 8:58 am
you couud also write just
output nil if @in == 1
so you dont need an event (if it just should do that..)
Postby billv » Wed May 29, 2013 9:15 am
Thanks guys....should have worked it out....nix showed me a good example of (==) a while
back in a on/off switch..I've been using it all the time as well.... :lol:
This is great.....now I've got some control in ruby....
Thanks.
billv
