double point slider
double point slider
I try to make a slider with 2 moving points that can cut the scale between 0 to 10 into 3 different areas. Both points should move forward and backward indeed and they should limit each other at the max and min points. For instance, if the right point is set to 6, the left point can't pass it. making it in green is a headache. Maybe Ruby can help here? Attached a picture for demonstration
https://imgur.com/cmSUqia
kortezzzz - Posts: 763
Re: double point slider
Here's a double slider I made a while back.
Hope it helps or gives you an idea of how to do it better.
Boom! Awesome.Thanks a lot billv
It works nicely here. Any chance that each of the three zones gets it's own color, instead of transparent background in area A and C?
