Why its ticking ?
Why its ticking ?
Postby Urnsoft » Thu Jun 13, 2013 2:28 pm
Hi Flows
Can someone explain this to me
Why it's ticking !?
I realized encapsulated MGUI is responsible !
Why it's always running.fsm
(35.59 KiB) Downloaded 1067 times
P.S
same behavior with Fonts,Brushes and Pens
the tick rate is approximately equal to 0.01 sec
Have a good day
Urnsoft
Re: Why its ticking ?
Postby chackl » Thu Jun 13, 2013 3:11 pm
Evertytime the View is changed it will trigger.
If you pack the MGUI Module and the ruby code to an extra module and ouput the trigger out of the module it will also trigger.
Everytime the Modul-Vie is vidible on screen and you move the view in flowstone it will trigger.
Regards
chackl
Postby Urnsoft » Thu Jun 13, 2013 5:02 pm
Hi chackl
You're right about packing the whole thing into module
and I know if the view changed it will trigger.
But as you can see there is no change in the view and its still triggering
I don't get this ,it acts like a ticker and burst every 0.01 sec(no redraw)
Is there a way to limit this process ?
P.S
did you get that trigger burst on your system ?
Urnsoft
Postby Nubeat7 » Thu Jun 13, 2013 8:16 pm
it doesn`t trigger by itself here!
Postby MyCo » Thu Jun 13, 2013 8:29 pm
It triggers, when you hover over connections. That's because FS redraws the screen when you hover over interactive parts to highlight it.
In the first example, it is triggering just because the view is visible. You can collapse the module and it stops happening.
MyCo
Postby Urnsoft » Thu Jun 13, 2013 8:54 pm
Well,It seems its in FS nature :|
Thank you all for taking time on this one
Urnsoft
