Lfo in ruby
Lfo in ruby
Postby borodadada » Sat Jun 22, 2013 2:38 pm
Hello, trying to write the LFO on Ruby, but it is not my true test, I think. I need a number generator for example from 0 to 1 and back again, what I want step , endlessly. Data format float for example, an example is attached ...
Do not get me to do the cycle, may be who knows how to do this?
Okey... screenshot.
http://rghost.ru/46940249/image.png
borodadada
Re: Lfo in ruby
Postby Tronic » Sat Jun 22, 2013 2:56 pm
missing an important parameter
which increase-rate should reach?
seconds, milliseconds or more?
Tronic
Re: Lfo in ruby
Postby borodadada » Sat Jun 22, 2013 3:50 pm
sorry, I find it difficult to translate this answer
borodadada
Re: Lfo in ruby
Postby Nubeat7 » Sat Jun 22, 2013 3:58 pm
why not putting the values in an array and increase the index with time - is this possible? (i`m not at home atm..)
Re: Lfo in ruby
Postby borodadada » Sat Jun 22, 2013 4:14 pm
arr = [1, 2, 3, 4, 5, 6,.....] ?
arr[0]
arr[1]
arr[2]
borodadada
Re: Lfo in ruby
Postby Nubeat7 » Sat Jun 22, 2013 4:20 pm
i tought a while loop .. which runs as long as input x is on
Re: Lfo in ruby
Postby Nubeat7 » Sat Jun 22, 2013 4:31 pm
something like:
i = 0
values = [your values]
while @inX  #or what ever condition
  output values[i],t+2.2
  i += 1
but don`t know if the syntax for the time adding works like this (still not at home)
Re: Lfo in ruby
Postby borodadada » Sat Jun 22, 2013 4:37 pm
If I'm not mistaken, this ruby can not use loops.
borodadada
Re: Lfo in ruby
Postby nix » Sat Jun 22, 2013 5:15 pm
What you want is a Ruby wavetable osc maybe,
and sure u can use feedback loops in Ruby.
I can help in the next week
nix
Re: Lfo in ruby
Postby Tronic » Sat Jun 22, 2013 5:48 pm
borodadada wrote:sorry, I find it difficult to translate this answer
your ruby LFO needs to work with the audio or just for the greens?
at what speed must run the increase of the step for your counter?
Tronic
Users browsing this forum: Majestic-12 [Bot] and 15 guests
