Get relative path
Get relative path
I'm looking for a way to get relative path so the application will always open/look in relative subfolder to application/executable/vst. Start folder and sysfolder primitive can't get this path.
In ruby:
File.expand_path(File.dirname(__FILE__))
this will get ruby path (windows\system32) folder.
I want to setup internal file list that will always look for files in specific subfolder in app relative path.
In ruby:
TrojakEW - Posts: 111
Re: Get relative path
"Find Files" primitive maybe?
That should give you the files in a specified folder. . . which you can test against.
- Drnkhobo
There's a primitive called 'Start Folder' - returns the location of the exe/plugin.
- strangeChild
Oh I miss option for start folder primitive to set up path while testing inside flowstone. It works thanks for help.
