USBLib Ruby - Using Libs with flowstone
Hello!
I have an DMX Interface here that is NOT FTDI ^^ - It has also No MIDI or any HID - It just has a "Standart" USB-Driver
delivered by the vendor.
It i install a standart usbdriver by zadig -> Same result
So no i was asking me if i could read out ALL USB Data - and i found this one here:
https://github.com/larskanis/libusb
Would that be possible?
Regards
Regards
chackl - Posts: 233
Re: USBLib Ruby - Using Libs with flowstone
I guess not, because you could not trigger the ruby module, at the same data rate of USB.
you must have loop-callback from external interaction.
you can not do, as it has been implemented in ruby FS, it runs only when required by a trigger,
it will occupy the thread and when executed will release the thread.
if you try to occupy the thread out of the set limit, it will turn off the ruby module by putting it in the OFF position.
I repeat, until there will be the opportunity to be able to read external dll
you can not implement anything that is not already implemented.
- Tronic
Users browsing this forum: Majestic-12 [Bot] and 17 guests
