Simple Gain Compensation thing
Hey I'd like to have an automated gain in a overdrive that will
copensate the drives gain knob. What I mean is when I turn the over drive to 2 I need a gain (volume only) knob before it hits the output to be -2, that ofcourse beeing interactive with the original drive know so I don't have to adjust the value all the time!
I'm sure that you can help me with this !
Wishx - Posts: 68
Re: Simple Gain Compensation thing
anyone ?
Wishx - Posts: 68
Seems my description is not clear, I mean use a overdrive but not have an icrease or decrese in level just a THD/ Distortion effect with no gain increase/degrease
Wishx - Posts: 68
Hi Wishx,
To get some help on this, you should really post up a schematic of what you have going.
RJHollins wrote:Hi Wishx,
Hey I mean in the default overdrive design, just that realy
Wishx - Posts: 68
Wishx wrote:Hey I'd like to have an automated gain in a overdrive that will
this will be not that easy, because when you turn the amp value to 0 you hear nothing so -2 will not have the effect you want, so i would recommend to transfer values to db, you can find different transferfunctions in steph tfs ` knob examples here:
viewtopic.php?f=3&t=641&start=50
maybe it would be easier to have 2 knobs, one for drive and one for volume...
you can find infos on gainreduction here:
http://www.synthmaker.co.uk/forum/viewt ... ion#p80885
Nubeat7 wrote:Wishx wrote:Hey I'd like to have an automated gain in a overdrive that will
Thank you, I will have a look and see what I come up with. Will let you know if something comes up
Wishx - Posts: 68
Deleted my previous reply so he re is a schematic of how this works manualy, now what needs to be done is the for example having the fr in christians vst analyzer stable at 0 changing only the THD. Can't figure out how to use this sort of ;auto gain; thing
knob2.2 (1) update2.fsm- (11.48 KiB) Downloaded 1008 times
Wishx - Posts: 68
i would leave the vol inside to adjust the main vol but you can adjust the drive vol down while turning drive up like this:
hope this helps
hope this helps
