Ruby question - creating random size arrays ad hok
Postby kortezzzz » Fri May 03, 2019 7:05 pm
There is a feature that I wondered if Ruby can do.
What I'm looking for is a module that can output a random size array that based on fixed given values. For example:
If I feed to first input the value 34 and to the second input the value 4, the output then would be
34
34
34
34
Any chance that it's doable?
kortezzzz
Re: Ruby question - creating random size arrays ad hok
Postby tulamide » Fri May 03, 2019 7:34 pm
output(0, Array.new(@size, @object))
sends to the first output, size and object being inputs, where size needs to be a number. Note, within Ruby it is @size times the SAME object)
use the event method if you only want to output, when a specific input is triggered.
Postby trogluddite » Fri May 03, 2019 7:36 pm
Oh yes, Ruby makes that nice and easy.
You don't have to create an Array using the brackets notation - they're objects, just like everything else, so have a 'new' method, and it's surprisingly flexible...
# A new, empty Array.
my_array = Array.new
# A new Array of the given size, with all elements set to nil.
my_array = Array.new(size)
# A new Array of the given size, with all elements set to 'value'.
my_array = Array.new(size, value)
# A new Array of the given size, with each element calculated separately in a code block.
my_array = Array.new(size) do |index|
  # Compute a value for the element, using the element's 'index' if necessary.
### OR ###
my_array = Array.new(size){|index| #Calculate }
There's one little caveat that you have to watch out for, depending what you want inside the Array. The "Array.new(size, value)" form doesn't make a new copy of the value for each element, they're all references to the original object. That's no problem for simple, numeric elements, but can catch you out if you're using, say, Strings or nested sub-Arrays...
# All elements point to the same String...
my_array = Array.new(10, "hello")
my_array[3].upcase!   # Alters the String "in-place" without creating a new one.
my_array[3] #=> "HELLO"
my_array[9] #=> "HELLO"  -- oops, probably not what we wanted!
# Unique, but identical elements...
my_array = Array.new(10){|index| "hello" }
my_array[3].upcase!
my_array[9] #=> "hello" -- that's better!
@tulamide - you beat me to it! :D But I thought the "same object" thing was worth going into further, as it's such a common "gotcha" for new Rubyists when using container classes.
Postby tulamide » Fri May 03, 2019 7:41 pm
@trog
That's totally fine! I was just too lazy to go into details :mrgreen:
Postby kortezzzz » Sat May 04, 2019 12:06 am
Thanks guys :D Works great
kortezzzz
