PWM primitive not working?
Postby Asbjørn » Sat Jan 29, 2011 11:22 pm
I'm trying to pulse a digital out port on a Phidget interface board, the only way I've found to do this is with the PWM primitive, but It doesn't seem to be working.
Am I doing something wrong, or is there a bug in the PWM primitive?
Asbjørn
Re: PWM primitive not working?
Postby Embedded » Sat Jan 29, 2011 11:50 pm
Yes, this is totally wrong for what you are trying to do! (FYI There was a bug in the PWM but this was fixed in the last version)
The blue connections in FlowStone are dedicated to audio!
The Green stuff is for data!
Here is a very simple pulse project in 'Green' that is ideal to connect to a Phidgets digital output:
pulse.fsm
Digital pulse project
(515 Bytes) Downloaded 1468 times
Embedded
Postby DSP » Sat Jan 29, 2011 11:54 pm
There are some good examples that you can learn from!
Here is a knight rider example, this one uses a counter:
http://www.dsprobotics.com/support/viewtopic.php?f=11&t=132
If you connect your Phidgets digital outs to the outputs of the LEDs in this example you will have a hardware equivalent of this Knight Rider Example.
DSP
