[SOLVED] Ruby component problem
Postby Dave_Scream » Mon Oct 07, 2013 7:04 pm
Hello.
I have problem with a Ruby component.
My problem in 1 screenshot:
and there is info from manual:
so why error?
Also.
input compare with name not work.
"if (i=0)" - work,
"if (i=="freq")" not working.
this is a working code, because in FL Studio version it works good. But in standalone it throw errors. But I read manual for standalone version and it have section for clearEvents...
whole code
def init
   @ntick = 0
   @counter = 0
   @main_freq = 0
   @ticking = false
   @min_delay = 0.2
   #input "state", true, time+1
def freq_setup
   if @freq <= 0
      @main_freq = 0
   else
      _mfreq = @period.to_f / @freq.to_f
      if _mfreq < 0.1 then
         _mfreq = 0.1
      @main_freq = _mfreq
def event i,v,t
   if (i=="freq" || i=="period" || i=="state")
      watch "f", "lol"
      clearEvents
      freq_setup()
      watch "mfreq", @main_freq
      if @state && @main_freq > 0
         @ticking = true
         input 100,nil,(t+@main_freq)
      else
         @ticking = false
   case i
   when 100 #main_timer
      if @state
         watch "main_timer", t
         input 100,nil,t+@main_freq
         rnd = @min_delay + rand((@main_freq.to_f-@min_delay)*100.0)/100.0
         watch "rnd", rnd
         input 101,nil,(t+rnd)
      else
         @ticking = false
   when 101 #event
      output "out"
      output "led", true
      input 102,nil,t+0.1
      @counter = @counter + 1
      output "counter", @counter
   when 102 #led off
      output "led", false
Dave_Scream
Re: Ruby component problem
Postby Dave_Scream » Mon Oct 07, 2013 7:24 pm
Allright. FL Studio have version 3.0.2
My standalone version is 3.0.0
3.0.0 is not support clearEvents and connector labels.
version history for 3.0.2:
- New connector referencing in the Ruby component allows you to use an index or a label name to refer to a connector
- New clearEvents method that removes all pending events posted for the Ruby component from which it is called
Dave_Scream
Re: [SOLVED] Ruby component problem
Postby trogluddite » Mon Oct 07, 2013 10:42 pm
Something we'll have to watch out for this - FL is one step behind, and the updates are much more often than they used to be.
Would be good if we try to remember to say "Built with version XXX", when posting schematic files.
