Ruby question - Filtering array duplications
Postby kortezzzz » Thu May 16, 2019 11:29 am
I tried few methods for this from the Ruby guide, but couldn't translate them with correct syntax in FS.
The example:
We have a given array:
dog
dog
frog
fish
cat
cat
We need to filter the duplications which are "dog" and "cat" and end up with
dog
frog
fish
cat
What would be the correct syntax for that?
kortezzzz
Re: Ruby question - Filtering array duplications
Postby DaveyBoy » Thu May 16, 2019 12:11 pm
Try array.uniq :)
DaveyBoy
Postby kortezzzz » Thu May 16, 2019 12:21 pm
Thanks Dave. I tried it but couldn't formulate it correctly. What exact syntax would you use to make it work in FS?
kortezzzz
Postby DaveyBoy » Thu May 16, 2019 1:30 pm
Like so:
["dog","dog","frog","fish","cat","cat"].uniq
Here's what I use for reference:
https://ruby-doc.org/core-1.9.3/Array.html#method-i-uniq
Hope this helps :)
DaveyBoy
Postby kortezzzz » Thu May 16, 2019 2:51 pm
Thanks,
But what if the array is not pre-determined (to "dog", cat", etc.)? Is there any kind of code that can recognize duplications in any given array?
kortezzzz
Postby DaveyBoy » Thu May 16, 2019 4:18 pm
Hmmm . . .I don't really understand what you're asking, uniq will remove any and all dupes as far as I know.
Can you be more specific in what you are trying to achieve?
DaveyBoy
Postby tulamide » Thu May 16, 2019 8:15 pm
DaveyBoy is right. The solution to what you described is Array #uniq, and it doesn't matter, what exactly is in the arrays, as long as the objects are comparable.
Postby kortezzzz » Thu May 16, 2019 10:38 pm
Ok, so there is a method for this :)
But how I write it correctly inside FS Ruby module? Tried to formulate a code, but it didn't worked for me, so seems like I'm doing something wrong.
kortezzzz
Postby RJHollins » Fri May 17, 2019 1:29 am
kortezzzz wrote:Ok, so there is a method for this :)
Post us an example of the code, so we can see what you are trying to do.
Postby kortezzzz » Fri May 17, 2019 10:42 pm
Found how to formulate it correctrlly in FS. An example schematic is attached.
Cheers!
(filtering array duplicates).fsm
(344 Bytes) Downloaded 866 times
kortezzzz
