Stream Router.
Stream Router.
Postby joejoe » Thu Oct 31, 2013 12:07 am
I need a stream router.
In reaktor you have a router that you use with a comparator(i.e. >,<,>=,=<, etc). to send the signal to two possible routes.
There doesn't seem to be one in FS. Further more if I use the DSP I wont be able to input Boolean.
Do I have to build a router?
joejoe
Re: Stream Router.
Postby CoreStylerz » Thu Oct 31, 2013 12:41 am
You have the stream comparators >,=>,<,<= search stream on the search bar.
PM me if you are interested.
CoreStylerz
Re: Stream Router.
Postby tester » Thu Oct 31, 2013 12:56 am
I think the question was about inputs/outputs, boolean ins paralel to signal ins. Or?
Anyway, if so, I'm not sure if this is handled through automation routines (and thus - preset system) or requires additional named ins open on front of the module.
Re: Stream Router.
Postby nix » Thu Oct 31, 2013 1:17 am
routers.fsm
(2.38 KiB) Downloaded 1050 times
Here you are Joe, hope this is what u need.
If you have any questions-shoot
nix
Re: Stream Router.
Postby joejoe » Thu Oct 31, 2013 1:37 am
Nix,
Yes those mods are exactly what I need thank you so much!
streamboolin was the main thing I was missing. doh :roll:
joejoe
Re: Stream Router.
Postby joejoe » Thu Oct 31, 2013 1:50 am
Actually I misspoke. I need a bool input and stream input and two stream outs one for a false condition and one for a true condition. I still don't fully get this DSP code with if statements.
joejoe
Re: Stream Router.
Postby nix » Thu Oct 31, 2013 2:21 am
multiplexer.fsm
(1.11 KiB) Downloaded 1045 times
I guess this is called a multiplexer.
No problems to try and do some more alterations if it isn't the mod u need.
I think with the if, it's a bool.
either true or false.
If true it will deliver the &ed value
nix
Re: Stream Router.
Postby joejoe » Thu Oct 31, 2013 3:53 am
Thanks Nick that seems to work!
joejoe
Re: Stream Router.
Postby Nubeat7 » Thu Oct 31, 2013 11:29 pm
the router could be done simpler putting all into "or" statements ("|") to avoid all the extra variables and the adding at the end, just take care to put the whole if statement in braces to work correct.
routers.fsm
(1.12 KiB) Downloaded 1053 times
Re: Stream Router.
Postby nix » Thu Oct 31, 2013 11:36 pm
thanks for that NuBeat 8D
will change the code in my synth to this neater logic.
I originally was using the integer indexed router
to modulate a formant filter.
ps- You're welcome Joe, hope the environment gels with you.
The 2 floats in the multiplexer can be deleted,
just didn't notice they got left in.
nix
