Legato and other glide options
What is an legato and how do i add such function and are there other glide options i can add?
- djbrynte
Re: Legato and other glide options
This gives good explanation for legato...
.http://en.wikipedia.org/wiki/Legato
Access legato/glide or port, by going in the "midi to poly module", open small module
called 'portamento'...inside is small knob, and a on/off switch.
It sounds like legato does not have separate notes.
That is a great Wiki, ta bill 8D
There is only one attack and decay phase within the tie.
The first note attacks, and last decays.
All the notes within the tie slide without changing volume.
Any thoughts on implementation peeps?
I'll think about it too.
Dident understand everything what do i change in The midi to poly module?
- djbrynte
djbrynte wrote:Dident understand everything what do i change in The midi to poly module?
i don't blame you...i forgot to mention the important part...MONO.....
Here a glide example.
Glide.fsm- (22.61 KiB) Downloaded 976 times
PM me if you are interested.
CoreStylerz - Posts: 327
thnx alot guys i will send the file to you soon corestyler. About the LFO display.
- djbrynte
