Req: a Mod to a Push Button/Toggle
Postby RJHollins » Tue Nov 05, 2013 9:35 am
Had this nice little module design going, and needed to add a push button toggle.
All going good till I then realized ... it no got a 'PRESET' module :o
Of course, I'm trying to match and compare to other stuff ..... nothing :shock:
So now I'm forced to throw my carcass to the ground in humble, ... "how to do this" :?
In need the PresetManager able to track the button, along with Automation.
also ... is there any link where I can learn more about what's involved and how to do this ??
Thanks for helping if you can !
8-)
Push Button-Toggle [Needs Preset]-1.fsm
(3.51 KiB) Downloaded 971 times
Re: Req: a Mod to a Push Button/Toggle
Postby Nubeat7 » Tue Nov 05, 2013 10:31 am
its easier to use s&h with not.. and just a last to set
Push Button-Toggle %5BNeeds Preset%5D-1.fsm
(2.94 KiB) Downloaded 979 times
Postby RJHollins » Tue Nov 05, 2013 11:21 am
Nubeat7 wrote:its easier to use s&h with not.. and just a last to set
That was a nice technique NuBeat.
BTW ... it worked a treat !
Just tying this into the 'Multi-function' slider. I only needed 2 states to track.
I'm still in the test module ... tomorrow I'll look to drop this into my project for test run.
AND study what you did compared to the orig button.
mmm ... slow learner :roll:
Thanks! 8-)
Postby Xtinct » Tue Nov 05, 2013 1:54 pm
I may be missing something here but why not just use a switch :?
Xtinct
Postby Nubeat7 » Tue Nov 05, 2013 2:10 pm
Xtinct wrote:I may be missing something here but why not just use a switch :?
what are you missing?
isnt it a switch?
Postby Xtinct » Tue Nov 05, 2013 2:32 pm
Yes but the standard switches have preset and auto built in
Xtinct
Postby Nubeat7 » Tue Nov 05, 2013 3:10 pm
think thats just a kind of taste if you want to use a ruby one or not..
Postby Xtinct » Tue Nov 05, 2013 4:13 pm
If you don't want ruby use a SM switch ;)
Xtinct
Postby Nubeat7 » Tue Nov 05, 2013 4:49 pm
not everyone uses SM..
and FS (and SM) is here to build your own designs, so why talking about stock modules instead of solving an issue, in my designs there is nearly every part designed by myself also selectors, buttons or switches because the stock ones are just examples how you could do it but you also could do it different, improve it or just be happy to do it by your own...
however, to build things like this by your own also helps you to understand how things working and can make your designs better.. so "why using stock modules when you can do it by your own?"
Postby RJHollins » Tue Nov 05, 2013 7:26 pm
Hi Xtinct ... I'm not exactly sure what stock switch you're thinking ... but I did go through my toolbox looking.
This particular push button I used had many of the useful features I needed ... till I realized the lack of preset. :o
I have gone in and made mods to components. I guess they would be considered 'no-brainers' ... but I could verify that my mod worked, and not mess up something else ... or at least I could work it till it did right.
Involving the PreSet Manager is something quite new for me. I'm in my first project that actually has it visible for use. The project is quite involved [for my level] ... so not much confidence in me adding Preset control into this button.
Another very important factor ... the opportunity to learn [or try] from experienced programmers here. Not just on my threads, but I like to follow the topics and discussion. Not just to learn about a PRIM or line of code ... but I see a thinking concept that I'm trying to absorb. [hard to explain .... but I'd guess I'm trying to move away from my normal, comfort, chaos mode] :lol:
This all started as curiosity, and a type of relaxing hobby. The more I can learn, I think the more fun this becomes ... just seems to take me too long :roll:
