Wraping the signal.
Wraping the signal.
Postby joejoe » Fri Nov 08, 2013 4:49 am
Has anyone made any components that wrap the signal between -1 and 1 or 0 and 1? Would you be able to share with me?
joejoe
Re: Wraping the signal.
Postby trogluddite » Fri Nov 08, 2013 12:40 pm
Hi joejoe,
Not at my FS machine at the moment - but copy/pasting this code into an assembly primitive should get you what you need (not tested!)
streamin in;
streamout out;
float one = 1.0;
float two = 2.0;
float half = 0.5;
movaps xmm0,in;
//Scale -1..1 to 0..1
addps xmm0,one;
mulps xmm0,half;
//Wrap to 0..1 by removing integer part.
movaps xmm1,xmm0;
addps xmm1,half;
cvtps2dq xmm1,xmm1;
cvtdq2ps xmm1,xmm1;
subps xmm0,xmm1;
//Scale 0..1 to -1..1
mulps xmm0,two;
subps xmm0,one;
movaps out,xmm0;
Postby joejoe » Fri Nov 08, 2013 2:47 pm
Thank you Tro, I do get sound out of it and when I bring my osc to 1 I get distortion which I suppose should be the case. Correct? When plugging a scope into it I don't get an output reading.
joejoe
