server issue
server issue
Postby csdsp » Sat Mar 19, 2011 9:09 pm
hi,
A new stange problem:
I work with a configuration with different server and client and i make a application with server all work fine i make exe all work fine i use the exe in another pc and it's impossible to open the server i install flowstone in this pc and the server work fine with the fsm i make exe and the server don't work i test with different PC and i don't understand why sometimes it's ok and sometimes not.
all with win pro 32
I test uninstall all uninstall the network, reinstall all and nothing. Strange strange strange for two pc with correct fonctionnality with flowstone or with exe after different test it's now impossible to open a server with exe.
csdsp
Re: server issue
Postby sal » Sun Mar 20, 2011 12:15 pm
it has already been reported here.
At the moment it doesn't work
sal
Re: server issue
Postby Cat5 » Fri Mar 25, 2011 11:11 am
It looks like this has been fixed in the new release:
http://www.dsprobotics.com/support/viewtopic.php?f=22&t=191
Cat5
Re: server issue
Postby csdsp » Mon Mar 28, 2011 7:01 pm
I've make a big install with 1 computer listen 6 others with 6 different ports. Because this install turn between one week i used a java server and also flowstone client. I've test this day change my 6 clients by 6 flowstone server without Java server and i have a strange disconnect sate. I've make a reopen function but after few test i've return with a java server. I'm not sure but it's possible for me to make change in one week and be sure server work fine.
csdsp
