how can i set the screen resolution of the .exe file
Postby geetesh » Fri Apr 08, 2011 2:56 pm
the resolution of the .exe file which i am generating is randon....
even working on the same file .fsm file
sometimes its resolutin is around 800*600
sometimes its resoution is around 1200*800
geetesh
Re: how can i set the screen resolution of the .exe file
Postby Morph » Fri Apr 08, 2011 3:03 pm
Generated .exe is the same size as your zoom level.
Morph
Postby Embedded » Sat Apr 09, 2011 10:21 am
Yes the default screen size is set by the zoom level in FlowStone (zoom slider top right).
You can also use the Zoom Module and the Full Screen module to select different screen resolutions for your EXE.
There is an example here: http://www.dsprobotics.com/support/viewtopic.php?f=11&t=190
Embedded
Postby geetesh » Sat Apr 09, 2011 11:25 am
thank you ....... that worked.....
geetesh
Users browsing this forum: No registered users and 25 guests
