how to combine
how to combine
Postby tester » Fri Dec 13, 2013 9:50 pm
I have two ruby instances, that share the same signal flow (and loop flow), just create different output. While one is responsible for generating randomness, second one - is responsible for filling everything (everything not excluded) with specific input value. How to combine (and optimize) them into single ruby instance? (I ask, because there are some performance issues with too many ruby instances within 1 schematic).
how to combine.fsm
(881 Bytes) Downloaded 901 times
Re: how to combine
Postby Tronic » Fri Dec 13, 2013 10:10 pm
:arrow:
how to combine_Tronic.fsm
(859 Bytes) Downloaded 900 times
Tronic
Re: how to combine
Postby tester » Sat Dec 14, 2013 1:04 am
Thanks. However - can these input triggers be separated (to 2 inputs)? So that ruby performs either randomization or cross copy, but not both at the same time?
Re: how to combine
Postby TrojakEW » Sat Dec 14, 2013 1:55 am
LIke that?
how to combine_Tronic_2trig.fsm
(885 Bytes) Downloaded 882 times
TrojakEW
Re: how to combine
Postby tester » Sat Dec 14, 2013 2:20 am
Yes, thank you.
