comparing 2 arrays (ruby)
Postby tester » Fri Jan 03, 2014 12:14 am
I need to do one of two things:
a) compare 2 arrays of elements and get an output with 0's (element at index not equal) and 1's (element at index equal)
or
b) determine which elements on input array changed after single retrig, and get an output like described above.
I guess the (a) is easier to implement.
It would be like this:
array1:
11
9
3
40
5
array2 (= array1 after change)
11
25
34
40
7
output:
1
0
0
1
0
(no sorting, no duplicate removing). How to make it with ruby?
Re: comparing 2 arrays (ruby)
Postby tester » Fri Jan 03, 2014 12:41 am
I think I found something, but... How to push these values to output?
I mean - ruby window shows correct answers, but when I add "output..." then it outputs only 0's or nothing.
compare-ary.fsm
(384 Bytes) Downloaded 896 times
Postby tester » Fri Jan 03, 2014 1:20 am
...not what I expected. Right now I can get this - works only with output changed to "string". But how to get simple array of 0/1 integers instead?
compare-ary1.fsm
(425 Bytes) Downloaded 886 times
Postby TrojakEW » Fri Jan 03, 2014 4:04 am
Now just simply convert them.
compare-ary1.fsm
(465 Bytes) Downloaded 923 times
TrojakEW
Postby Nubeat7 » Fri Jan 03, 2014 9:09 am
it is possible with just one map command too
for comparing things with 2 options the ternary operator ( ? : ) always comes very handy
it works like this:
(condition) ? (when true) : (when false)
output @in1.map.with_index { |x,i| x = x==@in2[i] ? 1 : 0 }
Postby tester » Fri Jan 03, 2014 11:36 am
Thanks!
Postby tester » Fri Jan 03, 2014 1:28 pm
So this little schematic will detect which values in input array have changed (per cycle).
detect-valchange.fsm
(743 Bytes) Downloaded 937 times
