Synthmaker Member's Forums
Postby Perfect Human Interface » Sun Jan 12, 2014 9:04 pm
So as far as I can tell, there are a lot of goodies on the Synthmaker forums hidden in the "members forums," which require a login to access. Also as far as I can tell, there's no way to sign up for the forums there. Presumably if you already have an account you can sign in but they've disabled sign up after the move to the new forums here.
What's a guy to do if he wants access to those goodies?
Re: Synthmaker Member's Forums
Postby tester » Sun Jan 12, 2014 11:24 pm
If you are FS or SM owner (legal purchase, full version) - it should be no problem to get you there. Just let me know on PM.
Postby Perfect Human Interface » Tue Jan 14, 2014 1:55 am
I only have the FL Studio version of Flowstone, so I assume then that this isn't enough to gain access to these "members forums."
Postby tester » Tue Jan 14, 2014 1:03 pm
Trog - what was the status of such situations on SM forum?
Postby trogluddite » Tue Jan 14, 2014 8:14 pm
tester wrote:Trog - what was the status of such situations on SM forum?
Not a problem I ever encountered - but judging by the ease with which spammers spread their demon seed there, I don't see that there is any technical reason that admission is barred.
Postby tester » Tue Jan 14, 2014 11:56 pm
If my english is correct (even GT had a problem to digetst the last part to my lang), I pass PHI's request further tomorrow or so.
Postby tester » Wed Jan 15, 2014 1:50 pm
PHI - I forwared your request to get SM "Registered Area" access to Malc (since he is the owner of SM board - he decides). If everything is fine, within few days you should be able to use that part of the forum.
Postby Perfect Human Interface » Wed Jan 15, 2014 7:59 pm
Sincerely thank you for going out of your way to do that.
Postby tester » Thu Jan 16, 2014 1:45 pm
PHI - you may login now on SM using your current user details, and you should have access to Registered Area too. Let me know if there are any problems. Have fun! ;-)
Postby Perfect Human Interface » Thu Jan 16, 2014 2:45 pm
Thanks so much.
