l need help
l need help
i need fix this SEQUENCER with mouse
Schematic3.fsm- (1.96 KiB) Downloaded 882 times
- madl
Re: l need help
nice one madl, your mouse logic for getting index (16 parts over the lenght) was wrong you need to get lenght and divide it by the pieces you want, to get a proper index (then you also could change the size like you want).. same goes for y axis, but with y axis keep in mind that 0 is up and bottom is full height so normally everything is "upside down" because in our mind 0 is at the bottom
i fixed this for you, you can do the same for the grid in back to change the size like you want..
madl seq fix.fsm- (1.85 KiB) Downloaded 889 times
Re: l need help
Was briefly checking out the NuBeat posting file ...
It seems that the mouse cursor and the 'boxes' are not lining up correctly [off by one in the vertical].
Re: l need help
i also forgot the set to -1 when rightclick.. fixed both and reuploaded it
