Help in synth (Work will pay)
If you fix some few things i will pay you 50-100$ for the work.
What need to be fixed.
1. Mod envelope doesent work. It changes the sound of the oscilator when change octave. I dont mean the pitch. It change somehow the freq sound. Everytime i when change the octave when the mod envelope is connected. It sounds like the filter of the sound is diffrent.
2. Connect the Sub oscilator perfect.
3. Make so the lfo can control the pan.
4 connect the lfo correct to phase and Mix.
5. Make so the lfo can control the filter perfectly.
6. check so i connected everything right about the mod envelope. (Also the hold stolen retrigg).
7. Check so the silde is right done.
- djbrynte
Re: Help in synth (Work will pay)
I can work for you
PM me if you are interested.
CoreStylerz - Posts: 327
