Mouse selection with picture
Postby rustyou » Mon Feb 10, 2014 10:49 pm
Hello,
i would like a image who change when i clik with my mouse. For to have a second picture after the clik.
How shall we do it?
Thank you,
rustyou
Re: Mouse selection with picture
Postby Xtinct » Mon Feb 10, 2014 11:14 pm
Toggle switch loads images for on / off
Xtinct
Postby rustyou » Tue Feb 11, 2014 10:09 pm
Yes, but i want cliked on the picture for to see a second picture..... ?
without seeing switch... (only picture)
rustyou
Postby RJHollins » Tue Feb 11, 2014 10:23 pm
rustyou wrote:Hi,
It's a neat trick, but what you can do is place a switch in with the picture ... expand the 'mouse area' to include the full pix if you like ... then, the trick ... HIDE the switch or remove the switch graphics.
Postby rustyou » Tue Feb 11, 2014 10:36 pm
Ok,
Possible to have an exemple.. ?
Thank you,
rustyou
Postby Jay » Wed Feb 12, 2014 3:43 am
here you go! load your images with the modules properties panel
2pic.fsm
(167.43 KiB) Downloaded 1019 times
regards
Jay
Postby rustyou » Wed Feb 12, 2014 7:13 pm
Hi :)
Yes it's good, but it's possible to charge different size for the picture ?
The first small... with a size define and the second big with a other size define ??
Thank you,
rustyou
Postby billv » Wed Feb 12, 2014 10:42 pm
Yeh..you got it...just define the bitmap size.
Invisible switch.fsm
(5.95 KiB) Downloaded 979 times
billv
Postby RJHollins » Thu Feb 13, 2014 12:17 am
some good examples guys ...
billv ... your example is maintaining the same mouse 'active' area, rathing than changing with the bitmap size.
Postby billv » Thu Feb 13, 2014 3:33 am
RJHollins wrote:billv ... your example is maintaining the same mouse 'active' area, rathing than changing with the bitmap size.
Good point..... ;) ...he might prefer it like that..
If that behaviour is required, he can just make another switch, re-size it, then switch it
same time as the the bitmaps.
Invisible switch_alt.fsm
(6 KiB) Downloaded 995 times
billv
