How to make presets diffrent name?
Postby djbrynte » Sun Feb 16, 2014 4:19 pm
now the presets use txt. Is it poissble to do so the presets only use fxp for example as name and cant load txt file name?
I think i found it in the preset manager. Can i also change the file type?
At least so it looks diffrent then txt file.
I think it worked ;) looks so!
djbrynte
Re: How to make presets diffrent name?
Postby Jay » Sun Feb 16, 2014 9:20 pm
FXB and FXP files are old school Cubase VST preset files that used to be made within the daw with the save as FXP/FXB feature, now disbanded in cubase back in version 4 i think , They use VST3preset file type nowadays! sonar still imports them im think but im not sure if it exports them!
if you really want to provide them for people i think you will have to export them from a vst2 preset compliant daw or export vstpreset files and use a convertor application like extreme sample converter or FXtractor to convet them to FXP/FXB
most people are looking for ways to convert FXP and FXB to other more modern and usable formats these days!
why do you want them in FXP? Flowstones preset system cant use them!
regards
Jay
Postby djbrynte » Mon Feb 17, 2014 12:07 am
I just wana use something diffrent then txt. Thats working.
djbrynte
Postby Jay » Mon Feb 17, 2014 6:09 pm
well you could use VSTPreset files! im pretty sure they are compatable with nearly all hosts and daws! ;)
Jay
Postby djbrynte » Mon Feb 17, 2014 6:25 pm
When i changed the name of txt to fxp. Then the txt file get diffrent format :P and it worked to load them to. Im new into this i need help how do i do this?
djbrynte
Postby Jay » Mon Feb 17, 2014 6:41 pm
yup it will work to rename the filetype to whatever you like but it is still a txt file and the FXP format is used by several other applications, so it will cause confusion to other apps if used on the same computer by your customers/users
make up you own extension name and that will solve that problem! here is a list of extensions in use by other applications http://en.wikipedia.org/wiki/List_of_file_formats
so you dont want another preset type, just the illusion ofthem not being txt files?
Jay
Postby djbrynte » Mon Feb 17, 2014 8:57 pm
Yes exactually The illusion :p
djbrynte
