Reaper Crash :|
Reaper Crash :|
Postby RJHollins » Sun Feb 23, 2014 7:07 am
Working along on my project ... things going well ... added in some new features ... things looking good ...
until ... I export as a VST, and load into REAPER .... which then crashes :o
From my crash log, I see this ...
Event Type: Error
Event Source: Application Error
Event Category: None
Event ID: 1000
Date: 2/22/2014
Time: 10:12:14 PM
User: N/A
Computer: xxxxxx
Description:
Faulting application reaper.exe, version 4.5.9.0, faulting module nvc-mammoth.dll, version 0.0.0.0, fault address 0x00359561.
For more information, see Help and Support Center at http://go.microsoft.com/fwlink/events.asp.
Data:
0000: 41 70 70 6c 69 63 61 74 Applicat
0008: 69 6f 6e 20 46 61 69 6c ion Fail
0010: 75 72 65 20 20 72 65 61 ure rea
0018: 70 65 72 2e 65 78 65 20 per.exe
0020: 34 2e 35 2e 39 2e 30 20 4.5.9.0
0028: 69 6e 20 6e 76 63 2d 6d in nvc-m
0030: 61 6d 6d 6f 74 68 2e 64 ammoth.d
0038: 6c 6c 20 30 2e 30 2e 30 ll 0.0.0
0040: 2e 30 20 61 74 20 6f 66 .0 at of
0048: 66 73 65 74 20 30 30 33 fset 003
0050: 35 39 35 36 31 0d 0a 59561..
does this mean anything to anyone ??? :roll:
I don't even know where to start looking for the problem :oops:
Something else I notice ... this was a few days earlier when FlowStone crashed on loading my schematic:
Event Type: Error
Event ID: 1000
Date: 2/20/2014
Time: 1:10:09 PM
User: N/A
Computer: xxx
Description:
Faulting application flowstone.exe, version 3.0.4.0, faulting module msvcr90-ruby191.dll, version 1.9.3.0, fault address 0x0005b5ea.
Data:
0010: 75 72 65 20 20 66 6c 6f ure flo
0018: 77 73 74 6f 6e 65 2e 65 wstone.e
0020: 78 65 20 33 2e 30 2e 34 xe 3.0.4
0028: 2e 30 20 69 6e 20 6d 73 .0 in ms
0030: 76 63 72 39 30 2d 72 75 vcr90-ru
0038: 62 79 31 39 31 2e 64 6c by191.dl
0040: 6c 20 31 2e 39 2e 33 2e l 1.9.3.
0048: 30 20 61 74 20 6f 66 66 0 at off
0050: 73 65 74 20 30 30 30 35 set 0005
0058: 62 35 65 61 0d 0a b5ea..
again ... no idea what to do :|
Re: Reaper Crash :|
Postby tester » Sun Feb 23, 2014 3:36 pm
Seems to be related with ruby files. My guess is. Either source ruby guts are damaged (thus exported files will also not work correctrly) or there is a conflict between some exports.
I would try to remove all ruby libs created by FS / FS apps, or I would try to reinstall the Flowstone (remove completely and install again). I would check the older iteration of the project (the one that worked) - if it still works, and this would give me the idea what has changed (and in what way ruby routines were involved; maybe some shared operations cause this). I would remove other FS plugins, to see whether reaper starts with this one only (or at least I would do some rescan on plugins, to clean the cache). At least a point to start with.
I noticed too, that my (standalone) apps have often "crash pattern". When I export the app, and start it in a new location - then first run (only first run) tends to crash it. Then it works fine. Also - when during loading I play with the main gui window and move it on the screen - it tends to crash from time to time. Hmm... Maybe somewhere a redraw limiter could help?
Re: Reaper Crash :|
Postby RJHollins » Sun Feb 23, 2014 7:32 pm
Hi tester,
This is the first time I'm crashing Reaper with a FS-VST. When I go back to an earlier version schematic, I am able to get a working version ... so ... something happened along the way.
I've tried to temp remove some of the updates I did [moving them outside of the main VST module], then re-export, but Reaper still crashes on the Re-Scan.
When I go back to the earlier version, Reaper scans it fine and it works .... so I guess I have to start there and slowly add in the updates and verify.
As to the FS crashes ... I have seen this too. When it happens, it is usually the first time ... the second time usually works :|
I DO notice that I'll see the 'reddish box' outline when first loading a schematic [like a RUBY overload] but that was usually brief.
Oh well .... got to track this down :|
Re: Reaper Crash :|
Postby RJHollins » Mon Feb 24, 2014 2:27 am
Update news ...
Well ... went back to an earlier schematic version that DID compile and load as a VST ... and started the slow debug, modify process.
At first, it seemed that a small, un-used graphic being removed [cause it was no longer needed] would bring on the crash went I sent it to Reaper .... that was really strange [it was a RUBY graphic].
Well, that made no sense ... so I continued to re-add all the new features/mods that I had originally planned for. Each time I did a VST export and test in Reaper. Everything continued to work ... UNTIL ... my final little mod/feature.
This immediately brought the crashing back.
Looking closely into the module, I had a series of wireless Inputs and Outputs happening. They ALL worked correctly in FS ... but crashed Reaper. Disabling the wireless ... Reaper was happy.
hmmm .... I looked at the 'naming convention' I used in the wireless, and recall a TROG post that talked of this topic.
So .... I renamed the wireless OUTPUTS, and complimented their receiver with the same new name.
Export to REAPER .... big smiles :D No more crash on initial scan.... AND, the VST opened properly.
Well ... I'm happy that I got all the features in ... lost a day in the process ... :roll:
The disturbing part ...
Honestly ... try like heck to avoid crashing ... but, I would have thought FS would have complained :? I guess somethings can slip by.
Well ... I've learned a small lesson here. FIRST ... continue to do INCREMENTAL Numbered saves of a project ! :!:
Add to this .... much more export testing in the host during dev.
Anyway ... though I'm not absolutely certain the exact cause, it DOES appear to have been a naming conflict in the wireless connects that was culprit.
As an aside ... I did actually improve what my original design was to be ... so not a total loss by any means ... just a bit a nerve racking and the familiar anguish :shock:
:lol:
off to play with the new VST toy ...
8-)
Re: Reaper Crash :|
Postby tester » Mon Feb 24, 2014 10:42 am
RJHollins wrote:Update news ...
8-)
Could you re-phrase what you mean?
Re: Reaper Crash :|
Postby RJHollins » Tue Feb 25, 2014 2:47 am
Hi tester ...
not sure I could do a re-phase that would help :lol:
But as to the naming convention that TROG talked about .... I found the link:
http://www.dsprobotics.com/support/viewtopic.php?f=2&t=2257&p=10446#p10446
as with most of TROG's post ... something to study and learn from ! 8-)
Of course ... this had specific reference to RUBY ... I THINK my issue was slightly different, as I was feeding values in and out of a module. Basically, I was controlling 2 buttons in 2 different locations, but they both interacted off each other. Might have been a type of feedback loop going on.... OR ... something got confused [beside me] with the wireless connects.
Once I went back in and changed the naming, things righted themselves. Things can get messy when a programming experiment becomes part of the works. Coming up with label, connector NAMES can sometimes be a challenge. I try to name them something meaningful ... but I think this time I got bit :shock: :oops:
BTW ... I sure hope the TROG is well ... it has been quite some time since he's posted.
