Bug light meter vu
Bug light meter vu
Hello,
I have a bug or probleme in the meter vu (look project)
The light does not respond when i clik on the switch (on, off light of screen on, off)
Why ?
Why ?
bug light vu meter.fsm- (362.83 KiB) Downloaded 892 times
- rustyou
Re: Bug light meter vu
Hi !
Exemple of this solution please ?
Thanks you,
Thanks you,
- rustyou
i'm sure you can do it! just insert a redraw primitive inside the modules where you select between the 2 images and trigger it with the switch signal
Look !!
I'm happy !
Thanks you so much for you help
I'm happy !
bug light vu meter.fsm- (362.86 KiB) Downloaded 919 times
- rustyou
