Why is this not working?
Postby joejoe » Thu Mar 13, 2014 2:11 am
Hello, I'm trying to get this DSP code to route signals to two different outputs. It seems to work ok with a simple Boolean true/false control, but will not work when I tie my oscillator up to it. Please see my attached file.
router testing1.fsm
(126.93 KiB) Downloaded 927 times
joejoe
Re: Why is this not working?
Postby nix » Thu Mar 13, 2014 2:35 am
router testing1_0.fsm
(128 KiB) Downloaded 898 times
I'm not sure why it doesn't work.
Will keep tweaking it and come back.
Here it is working with streamin, not streamboolin
btw, it's good practice to turn the ASIO driver off before saving a file.
It can cause the schematic to crash when loaded.
nix
Postby nix » Thu Mar 13, 2014 2:56 am
router testing1_1.fsm
(128.11 KiB) Downloaded 914 times
Here it is working with the bool.
The reason the original doesn't work has something to do with
bools not truly being numbers IMO.
It does work when you reference 0 though.
Troggie can tell us what identifier it is for streambools I reckon.
nix
Postby joejoe » Thu Mar 13, 2014 11:31 pm
Nick, thank you very much man!
Would you happen to know where I could get a full list of expressions for the DSP component? The manual seems to only list a few of them.
Also I saw your web site you posted been meaning to check them out as soon as I get the time.
-Joe
joejoe
Postby nix » Fri Mar 14, 2014 11:18 am
Welcome mate 8D
I think there are only a very few commands for the DSP codebox,
I have never seen the full list, it would be a nice resource though.
Hope you like something of the VSTs of mine-
hehe Tampler is such a cool name we should work on the FM sampler.
We need to tune the FM somehow, so it kinda syncs up with the carrier-
not so noisy maybe.
nix
Postby Nubeat7 » Fri Mar 14, 2014 9:12 pm
http://softpixel.com/~cwright/programming/simd/sse2.php
here you can find all sse and sse2 commands but not all are supported in FS
for your code example, you could do the comparsion also inside the code which doesn`t make the code more complicated.
streamin in;
streamin thresh; //0.3
streamout a;
streamout b;
a = in >= thresh & in; // a = in if in is greater or equal thresh
b = in < thresh & in;  // b = in if in is less then thresh
