Generated EXE get to 100% CPU after close
Postby chackl » Tue Mar 25, 2014 8:14 am
Hello!
What could be done, if an exe does not close in background and if it just eats up 100% cpu on a single core after closing it?
EXE was in fullscreen and got exit by the primitive.
Regards
C.Hackl
chackl
Re: Generated EXE get to 100% CPU after close
Postby Tronic » Tue Mar 25, 2014 8:55 am
taskkill info link
file bat with this line
taskkill /f /fi "status eq not responding"
Tronic
Postby tester » Tue Mar 25, 2014 11:37 am
I remember there was a discussion here on ruby and overload with amount of ruby modules. But if this is exe fullscreen only - I guess this isn't it.
Postby chackl » Tue Mar 25, 2014 12:48 pm
Oha... there a realy LOADS of very BIG ruby modues inside :shock:
The fsm measures about 3MB, the uncompressed EXE about 10mb and there is about 90% ruby inside :/
An the Ruby code inside is timer-based so it is executed about 10 times each second. The Exe needs about 20% CPU on a 2,1 GHZ dual core here.
An no i checked it now - it is not a fullscreen issue.
Is taskkill the only way to get this for the moment?
chackl
Postby Tronic » Tue Mar 25, 2014 2:17 pm
hard to know without more info.
I will say things at random:
You have open connections?
save some files when closing the app?
tried to stop the ruby garbage collect before closing the app?
Tronic
Postby chackl » Tue Mar 25, 2014 2:31 pm
Tronic wrote:hard to know without more info.
Everything is stopped before exit - the exit comes with a timer after stop after 500ms.
There are no files saved and i also tried to reset the ruby objects.
But it randomly does not exit
regards
chackl
Postby Tronic » Thu Mar 27, 2014 9:28 am
what you mean with
try to disable the ruby garbage collector with the ruby code command:
GC.disable
and also you can utilize the primitive
[ About to Close ]
to send the trig to the primitive
[ Exe Quit ]
when all is done before to quit.
Tronic
