Mix
Mix
Postby mit2 » Sun Apr 06, 2014 1:40 am
work
mit2
Re: Mix
Postby Nubeat7 » Sun Apr 06, 2014 8:26 am
hello mit2
not sure what you want -
a switch: would be your described if else scenario
a crossfade: fades from A to B mixing the signals
here are the 2 modules (for stream as code)
crossfade_n_switch.fsm
(1.42 KiB) Downloaded 943 times
Re: Mix
Postby mit2 » Sun Apr 06, 2014 1:21 pm
work
mit2
Re: Mix
Postby Nubeat7 » Sun Apr 06, 2014 1:50 pm
you mean
if mix == 0 then dry input
if mix > 0 then wet *mix
would be like this then
streamin a; //dry in
streamin b; //wet in
streamin mix;
streamout out;
out = (a&(mix<=0))|((b*mix)&(mix>0));
you just need to change 'b' to '(b*mix)' in the switch module
btw are you sure you didn`t confuse > (greater then) and < (less then)
also where is the double stream?
if this doesn`t help,you better post a schematic..
Re: Mix
Postby mit2 » Sun Apr 06, 2014 7:35 pm
work
mit2
Re: Mix
Postby KG_is_back » Sun Apr 06, 2014 7:58 pm
streamin dry;
streamin wet;
streamout out;
streamin mix;
out=wet*mix+dry*(1-mix);
Re: Mix
Postby Nubeat7 » Sun Apr 06, 2014 11:17 pm
KG_is_back wrote:
streamin dry;
streamin wet;
streamout out;
streamin mix;
this is also a crossfade...
i just use this instead:
out = a - (a - b) * fade;
because of less multiplication - it should be with better performance if i`m right and it has no extra float value for 1, but KG`s is easier to understand?
so you want:
and if mix < 0 (less then zero) it mixes the wet signal(with the filters) without input signal
so 0..-1 should mix the wet signal?
then just xchange the > and < signs in the code above
streamin a;
streamin b;
streamin mix;
streamout out;
out = (a&(mix==0))|((b*mix)&(mix<0));
note that the mix signal then needs to be 0..-1 and not like you wrote before 0..1
if mix range would be 0..1 in your scenario:
mit2 wrote:i want doit this if mix = 0
http://i61.tinypic.com/286toa8.jpg
and if mix < 0
http://i62.tinypic.com/1zovvde.jpg
this is schematic how has a look
it never can get the second signalway because mix is never < 0
work
Postby mit2 » Mon Apr 07, 2014 9:17 am
work
mit2
Re: Mix
Postby Nubeat7 » Mon Apr 07, 2014 10:43 am
its because the range of your mix slider is set to min = 0, max = 0 so the output of your fader is always 0, just set the max to 1 .....
Re: Mix
Postby mit2 » Mon Apr 07, 2014 10:57 am
thaks. I thought that I mix 0-1
mit2
