Key Pressed module question
Postby KimSteff » Fri Apr 25, 2014 1:21 pm
Are there a buffer build in to the key pressed module to avoid any missing keypress.down commands fra a PC keyboard ?
KimSteff
Re: Key Pressed module question
Postby KG_is_back » Fri Apr 25, 2014 9:04 pm
From what I can tell, the module checks whether given key is pressed at the moment it receives a trigger. So we may assume it doesn't actually check for keypress.down commands. I may be wrong though.
Postby tester » Fri Apr 25, 2014 10:13 pm
Generally it uses ticker, and since ticker is green - it may be less accurate (responsive) if many triggers are wandering.
