Built-in one click bank manager
Hi people.
I wanted to share with you a cute feature which is fun to use and will make live easier for any plugin user.
I'v already embedded a "one click preset manager" in my new releases, but this one allows the user
to load his favorite banks so fast, that he can trust it even at live shows. And if touchscreen\tablet
is used, thing become even better
I would like to thank Trog for his lovely "super-string" module. Thank you man. For this and for the inspiration.
So how to use it? very easy.
First, create your plugin's system folder on you hard-drive.
After system folder created,the "Find primitive will find any .txt files inside this folder and will create an array of their names. This array is actually your saved bank files list. this list will sent into Trog's superstring
module that allows one click menu performance perfectly.
from now on, every new bank that go be saved in you system folder, will show up immediately in
the "bank" list and is ready for use, with only a single click.
By the way, works great with touchscreens (made for live shows to use with windows 7 based tablet).
Example Synth with one click bank loader.fsm- (102.16 KiB) Downloaded 943 times
kortezzzz - Posts: 763
Re: Built-in one click bank manager
hmm seems to find the banks but dont update them when click on it, or how to load a bank from the list? just click on it or?
Works fine here.
Nubeat, it should work with a single click. Tested on 3 computers without problems.
On the next post ill upload a combined page of one click preset/banks manager embedded into a synth. Unless somebody else would like to take the challenge for fun?
Edit:
Seem like there have been a problem there. You are right nubeat7, the refresh didn't work fine.
i'm updating the original schematic with the fixed one. Sorry...
Edit:
