Vector knob enhancements
Since making a design strategy change ... I'm needing to switch from Bitmap knobs to Vector knobs.
I know this has been talked and designed over at the SM forum ... but here at FS it has been quiet.
This may be one of the least exciting project ... but, I can't think of most any project that doesn't need a knob or three.
The dilemma ... how to snazz-up a vector knob.
First thing I've tried is to add a 'triangle' marker as a third choice for an indicator [dot & line]. My attempt was to pull from another project and look to retro-fit ... I've got the filled triangle to display ... it rotates with the knob ... but for the life of me, I cannot get this thing to position properly.
In all good sense ... it is most likely a bad idea to try and retro-fit ... but I'm not getting my brain to help me at all.
So I wondered if the FS GURU's [and those that wish to join in], to help dress up the plain-jane vector knob.
There was also a cool idea presented that used 'dots' that help simulate grippers on the knob ... again something to spice up the look ... yet still maintain the vector flexibility.
I've enclosed the module that I've been hacking on. Somebody did a very nice job on this functional design. I like it because it can have defined steps, or be continuous. With a [CNTRL-KliK] it can reset to DEFAULT ... and its' re-sizable on the spot.
Anyway ... if interested ... or totally bored out of your skull
maybe we can get some vector 'love' happening.
Thanks Guys ... hope everyone is well !!
Here's the innocent example that I've been torturing
Re: Vector knob enhancements
that much fun ... huh
by Default arrow point straight up
- Dimmak01
Was it just my 'start angle' was incorrect ?
Yeap. start angle= 270 is correct.
- Dimmak01
Dimmak01 wrote:Yeap. start angle= 270 is correct.
OK .... well, I was just letting youse guys warm up on the EASY one
nah ... really, thanks for posting a fix for that. I just could not sus that one out
Say ... if you [or anyone else] would help tackle the 'other' feature
Inside there is a 'dots' module .... BTW ... I believe I tracked down the original author [or at least the main] ... I believe it was the talented 'NIX' that had this cool design idea [over on SM forum].
What it is, are a series of dots that surround the edge of the knob ring [diameter was adjustable, as well as the size of the dots].
What this did was allow this series of dots to move with the knob, in such a way that gave the illusion of 'gripper detents' around the knob. [instead of just a boring circle].
Anyway ... thought is was a really cool look [something to dress up the vector], and have been trying to adapt this into a basic vector knob design. [as yet, I've only gotten 1 small circle to display and move
I'm a gonna keep trying !
Just checking out the 'fix' version .... seems my support code is not correct.
The moment I resize the window to change knob size, the arrow display gets screwy
ok ... possibly a NEW solution going here for the Triangle marker.
still testing it out. Will post when I have it .... wish me luck
Heya Mr. Hollins,
It was me indeed who started the big vector knob project
over at SM. I really should have chimed in earlier here.
Anyway, I found the original version I did-
will look for the vector knob maker-
that was quite a build when it was finished.
I will see if I can add the dots to your one.
Best of luck with it!
-and thanks for the compliment(blush)
The way the dots where done was to draw each one,
and manually set the co-ordinates.
I think I used a star or similar shape as a template.
What about if we use an architecture similar to this knob->
Maybe I just like the layout on this one coz I didi it,
and it makes sense to me.
I can add the reset to default function to it,
if you like the architecture.
