arrays ruby and combinations
On ruby website there is something like this:
What I'd like to do is this.
First array to push trough combinatorics is made of numbers.
I'd like to get unique midpoints according to formula (A+B)/2.
If the array is:
100
200
300
then the output list would be something like this:
150
200
250
Second array to push through combinatorics is made of strings.
I'd like to get a list of combined strings that looks like this: A-B
If the array of string names is:
A
B
C
A-B
A-C
B-C
I refer to combinatorics, because order between two arrays is important (i.e. names and their numbers).
How to make it?
Examples:
a = [1, 2, 3, 4]
a.combination(2).to_a #=> [[1,2],[1,3],[1,4],[2,3],[2,4],[3,4]]
If the array is:
100
200
300
150
200
250
A
B
C
A-B
A-C
B-C
How to make it?
Re: arrays ruby and combinations
Wierd, never noticed that this one returned an 'Enumerator' instead of Array.
But handy, because '.map' can immediately follow without needing to convert to array in the middle - should be very fast!
NB) If you need exact 1 to 1 correlation between index of mid-points and index of Strings, remove '.uniq' - it will remove identical values, maybe leaving the number array shorter than the String array.
The string array must be exact to the array of numbers. By "unique" I meant unique index combinations (i.e. to avoid Ato B and B to A). In this step - output numbers refer to midpoint descriptions. Thanks!
Okay, question for step 2. Similar thing as above, but now we have two separate arrays of numbers and two separate arrays of descriptors.
What I would like to do here - is to combine each element from array 1 with each element from array 2.
It would be like this
Text arrays:
A
B
C
D
E
results in
A-B
A-C
A-D
B-C
B-D
B-E
And numeric arrays go in the same way, just by the equation: x - y.
So the end result - are two synchronized arrays, one with descriptors, one with calculated data.
How to make this one?
For the rest of things (picking indexes for values in specified range), I think I have working modules somewhere around.
Text arrays:
A
B
C
D
E
results in
A-B
A-C
A-D
B-C
B-D
B-E
A little help here please.
I think this is right - I'm guessing that "A-B, A-C, A-D" is a typo - should be "A-C, A-D, A-E". If not, I'm not quite sure how to make sense of the specification...
Yes, it was my mistake (long night; playing with new i-crap device since few days; the longer I have it the more I think I start do programming for them, but not because I like them - lack of apps that I would like to use...).
Thanks!
Thanks!
