ifthenelse for arrays in ruby?
Postby tester » Fri Jul 18, 2014 6:05 pm
How to make ifthenelse for arrays in ruby?
-> Input array
-> equals
-> conditions array
-> things to send to output
Re: ifthenelse for arrays in ruby?
Postby Tronic » Fri Jul 18, 2014 6:10 pm
Tronic
Postby Tronic » Fri Jul 18, 2014 6:13 pm
Tronic
Postby tester » Fri Jul 18, 2014 6:13 pm
...arrays...
Postby Tronic » Fri Jul 18, 2014 6:15 pm
Tronic
Postby Tronic » Fri Jul 18, 2014 6:19 pm
Tronic
Postby tester » Fri Jul 18, 2014 6:22 pm
I just would like to simplify this.
Basically there will be few of such units, each for different comparator. This is for splitting a list of strings according to numeric parameter placed within these strings.
Schematic1.fsm
(591 Bytes) Downloaded 1111 times
Postby Tronic » Fri Jul 18, 2014 6:28 pm
can you post a logical example of what you want?
Tronic
Postby TheOm » Fri Jul 18, 2014 7:10 pm
You could use group_by.
Schematic1_simple.fsm
(616 Bytes) Downloaded 1054 times
TheOm
Postby tester » Fri Jul 18, 2014 8:53 pm
Hi @TheOm.
Your solution still refers to ranges. I'd like to compare the input array to single element (what I posted above was unmodified module, that operates on ranges). Or rather...
@Tronic.
Simple case scenario. Let say that I have an array:
a
a
b
a
c
b
c
Concept:
Produce arrays of indexes that refer to specific values.
indexes @a
0
1
3
indexes @b
2
5
indexes @c
4
6
indexes @N
I'm still defining the concept, but I hope I made this one clear this time. :-)
