VELOCITY SENSIVITY ON A SYNTH???
hi guys,
I need help, I need to know how to make my synth velocity sensitiv]....no matter how hard I press the key it still plays at once level....help please....thankyou my friends u are SYNTH GURUS!!!!
- apoc123
Re: VELOCITY SENSIVITY ON A SYNTH???
In midi to poly module there is velocity output. Multiply it with your signal and you have what you want.
TrojakEW - Posts: 111
GOT IT ...THANKS TROJAKEW!!!
- apoc123
Hello,
I would like to have a precision...
It's written : "multiply it with you signal..."
But how can I multiply ?
Thanks a lot,
Thanks a lot,
- musella
Hello,
How can I multiply with my signal ?
I would like to have a velocity response when I hit my piano key and the sound Flowstone can do !
Thanks for your help !
- musella
In the search bar search with "Multiply"... You will find "Stream Multiply". Drag it in and connect it with Midi to Poly velocity.That's how you can multiply your signal. This component multiplies two Stream values together.
JC Conkato
rdgaudio - Posts: 32
hello,
I've founded the solution !
- musella
Hello, thanks for your answer ! I'll try your option.
I've founded VCA module just before your answer... It works perfectly !
- musella
