Dual monitors, dual applications
Postby Asbjørn » Sun Jul 17, 2011 3:05 am
I've got a challenge I can't find a solution to, I have two identical monitors side by side, and I have two different fullscreen applications made in Flowstone. How do I get the second application to show on the second monitor? Both applications appear on monitor 1.
Thanks
Asbjørn
Re: Dual monitors, dual applications
Postby Cat5 » Sun Jul 17, 2011 9:25 am
I think the only solution in full screen mode would be to make the 2nd application the same size as the dual monitor set (ie double width) and move everything to the right.
Cat5
Postby Asbjørn » Sun Jul 17, 2011 2:15 pm
Thanks, but that doesn't work, the grid is only 2000 pixels wide, I need it to be 1920+1920=3840 pixels wide to do that. Any other suggestions?
Developers?
Asbjørn
Postby Cat5 » Mon Jul 18, 2011 8:51 pm
I see, I've passed on your comments to the developers :)
Cat5
Postby Asbjørn » Tue Jul 19, 2011 2:16 am
Thanks! Are you an employee of DSP Robotics?
Asbjørn
Postby Cat5 » Thu Jul 21, 2011 8:20 am
No I just emailed them!
Cat5
Postby Asbjørn » Fri Jul 22, 2011 10:06 pm
OK, thanks for that! :)
Heard anything?
Asbjørn
Postby Asbjørn » Sun Sep 18, 2011 1:50 am
Flowstone crew, I really need help with this, what do I have to do to make this work?
Asbjørn
Postby DSP » Sun Sep 18, 2011 10:12 am
Is there a reason you can't just have one large application?
It's unlikely that what you want can be done as full screen mode takes over the whole screen and this is defined by the graphics card.
DSP
Postby Asbjørn » Sun Sep 18, 2011 3:22 pm
As I mentioned above, the reason I can't have one large application is the grid size limit of 2000x2000 pixels, it would have to be 3840x1080 to work with 2x 1080p monitors side by side. Unless there's a good reason for limiting Flowstone to 2000x2000, maybe it could be increased in the next version?
It's OK that full screen mode takes over the whole screen, but it should be possible to select which of the two screens (or more) it uses, examples of applications that can do this are VLC, Powerpoint and many more. It's not a limitation in Windows or the graphics card, it's a programming choice or bug by DSP Robotics.
Asbjørn
Users browsing this forum: No registered users and 35 guests
