unique random numbers ruby array
Postby tester » Mon Sep 22, 2014 4:57 pm
I know I have it somewhere, but can't find it.
How to quickly create in ruby - an array of specified size (how many items), made of unique random numbers (integers) in specified range (from..to)?
Re: unique random numbers ruby array
Postby TheOm » Mon Sep 22, 2014 5:50 pm
There's probably a better way, but I would do
(from..to).to_a.shuffle.take(size)
TheOm
Postby tester » Mon Sep 22, 2014 6:23 pm
Should be fine, thanks. I just need to pick some random graphic files from folder, to get different results per each click.
Postby billv » Mon Sep 22, 2014 9:52 pm
Sounds like you won't need this tester, but I will add it for sake of the 'thread title".
The array version of my Urn module will ensure every element remains unique
and non-repeating with every shuffle.
http://www.dsprobotics.com/support/viewtopic.php?f=3&t=2380#p14120
billv
Postby tester » Mon Sep 22, 2014 10:19 pm
What's wrong with what TheOm provided? It works, it's single line, and is resistant to borderline situations as far I can see (pool size vs declaration array size).
Postby billv » Mon Sep 22, 2014 11:30 pm
tester wrote:What's wrong with what TheOm provided?
Where did i say it was wrong?
Like i said tester..
billv wrote:Sounds like you won't need this tester, but I will add it for sake of the 'thread title"
As I wrote, the behaviour of my Urn array is different, and might be useful for someone
who see's this thread title, and seeking a alternative option.
billv
