Ruby output trigger?
Postby Subquantum » Thu Oct 09, 2014 9:02 pm
Can someone tell me the correct way send a trigger to an output in ruby?
For instance, if I want to send a boolean to a ruby output, I can use:
output 0,true
But if I want to send a trigger to a ruby output I can not use:
output 0,trigger
Subquantum
Re: Ruby output trigger?
Postby TheOm » Thu Oct 09, 2014 9:49 pm
It doesn't matter, you can send anything to the output.
I just do this:
output 0, nil
TheOm
Postby tulamide » Thu Oct 09, 2014 10:08 pm
Any data sent by definition also sends a trigger (with one exception: If you directly change the output array's data). So, as TheOm said, simply send anything (including nil). Just make sure the output type is a trigger then, the information will get lost but the trigger will be used.
Postby Subquantum » Thu Oct 09, 2014 10:52 pm
Thanks guys!
I thought it was going to be something simple like that.
Subquantum
