Ruby setViewSize
Ruby setViewSize
The user guide describes this method to resize a view within its parent. However, trying to use it raises a 'no method' error, and indeed the methods-call doen't list setViewSize, just getViewSize.
Any information on this? Especially how to set the view size without this method?
Re: Ruby setViewSize
I believe it is the FS 3.0.5 feature. There is no other way of setting view size as far as I'm concerned. You may cheat a little and use clipping and area redraws to simulate the behavior to some extend.
Ah, I see! Thanks. I wanted to add this as a feature to a control, but size set by the user when building the view is also sufficient.
I wonder why there isn't this feature in the FS primitives in the first place(on the Module GUI prim to be specific).
KG_is_back wrote:I wonder why there isn't this feature in the FS primitives in the first place(on the Module GUI prim to be specific).
Me too. It was one of the first things I wondered about when starting doing graphics. Would make life much easier
tulamide wrote:KG_is_back wrote:I wonder why there isn't this feature in the FS primitives in the first place(on the Module GUI prim to be specific).
It definitely would. Perhaps they didn't added it straightaway because there were some issues with recalculation of front panel (I can imagine this to happen when the frontpanel size suddenly changes, trowing redraws and viewArea triggers all over the place). But since they added it in ruby, the normal green version shouldn't be so much of an effort to add.
