Easy rotation of Knobs
Is there an easier way of creating knobs than using animations with a bunch of cells?
Is there a way of maybe ruby calculating the rotation and applying it to a static PNG (with single cell) image?
Thanks
Thanks
- glitchcpt
Re: Easy rotation of Knobs
You can use rotate prim to rotate parts of view. If I recall correctly Ruby contains similar command, so it should be possible there too
rotation knob.fsm- (1.38 KiB) Downloaded 726 times
Wow! this is perfect
Legend
Legend
- glitchcpt
