What To Do When Value Doesn't Propagate
Definitely one of the most frustrating problems I've run into while working in Flowstone is when a value doesn't propagate correctly through a schematic. It will seemingly get stuck at a specific point where the next node doesn't receive the correct value unless you manually click on it, even though everything connected before it has updated correctly. It of course doesn't appear to make any sense, but there does seem to be a solution.
When you find the point at which the value looks to be stuck, place a trigger blocker in the connection between it and the previous node. Then, wire a "trigger pass" (a module that contains only an input wired to an output with both nodes set to trigger) from the beginning of that block of code (e.g. the input of the module you're working in) to the node after the trigger blocker. Make sure this trigger link is connected last.
Cross your fingers and test your schematic again, and hopefully things will be working without a hitch now.
My hope is that if anyone else is finding themselves frustrated with this sort of issue they'll find this post!
- Perfect Human Interface
Re: What To Do When Value Doesn't Propagate
Thankyou!
Albert Einstein
Albert Einstein
JB_AU - Posts: 171
deleted by uploader
deleted
tiffy - Posts: 400
The trigger blocker is useful for when you want to control when something updates or limit triggers. Basically, you'd feed triggers from somewhere else. That way the value updates from the "somewhere else" triggers rather than passing the triggers you've blocked. A common example would be when redrawing GUI elements; because redraws are expensive and you might be sending 500 triggers in a second to a redraw even though your monitor can't refresh faster than 60 times a second, it's much better to just block the triggers and then feed more controlled triggers from a ticker instead.
tiffy wrote:I still don't understand the logic behind the need for a trigger blocker in any schematic
Trigger blocker is awesome.... combined with a s+hold you can easily control
how your circuits behave.
Trog's Trigger Tutorial is a must read....explains it all really well..he even breaks down the trigger order
with pictures so you can see how the signal moves..
http://synthmaker.co.uk/forum/download/file.php?id=6297&sid=e1d16e22338a5329b1b59032efbcae75
