Assembler component
Assembler component
Postby Shoo » Mon Oct 03, 2011 8:52 am
Why not accept this code?
push dx
push ax
mov dx,378h
mov ax,00002
out dx,al
pop ax
pop dx
How will be right?
Shoo
Re: Assembler component
Postby Morph » Mon Oct 03, 2011 5:06 pm
It's not ASM and i'm not sure what the code should do.
Here's the list of ASM opcodes: http://www.synthmaker.co.uk/dokuwiki/do ... s&s=opcode
Morph
Postby fixstuff555 » Tue Oct 04, 2011 12:11 am
I could be wrong, but it looks like to me that you are wanting to set a bit on a parallel port, as in LPT1? I saw your other post, and that code looks like that's what is going on. I'm not sure if hardware addresses are available in the assembly code primitive, but I could be wrong. That would be cool. I don't believe there is any support for a parallel port.
fixstuff555
Postby Shoo » Tue Oct 04, 2011 12:28 pm
Yes, I need to control LPT-port.
I'm very sad, that there was no support for parallel port. :cry:
Shoo
Postby DSP » Tue Oct 04, 2011 5:30 pm
FYI the assembler component is only for processing audio, as it the code component.
You cannot access the parallel port this way as it violates the windows conventions and will most likely cause your PC to crash!
One way to do this right now is to write a stand alone parallel port handler in C++ or similar language and use inter application communication via UDP to send the data to FlowStone.
DSP
Postby Shoo » Wed Oct 05, 2011 8:56 am
On the contrary - to send data to the port from FlowStone.
Someone could really help in this?
Put a module, or something else?
Thanks!
P.S.
C do not know how.
Shoo
