rotate a bitmap about it's centre
Postby nimbusgb » Tue Oct 11, 2011 9:29 pm
trying to rotate a bitmap of a compass card around its own centre.
Any pointers would be appreciated!
nimbusgb
Re: rotate a bitmap about it's centre
Postby nimbusgb » Wed Oct 12, 2011 6:49 am
might have sorted some of it but i need to calculate the centre of the plotted bitmap. If the gui display is resized then the centre of rotation moves and things go wrong.
I have attached a copy of my display but not sure if that encapsulates the bitmaps??
It should display this
Can I just add how blown away I am at this! What a cracking piece of software! The manuals could do with a bit of work, working out where to put things like the redraw of a bitmap is mostly trial and error but 2 days ago I had not heard of Flowstone and in one evening I produced a working compass display, got a feed from a com port going, filtered out a csv stream and can control my display from a piece of hardware.
Excellent! I'll certainly be spreading the word to some of the user groups I am in!
compass.fsm
(32.16 KiB) Downloaded 1360 times
nimbusgb
Postby Morph » Wed Oct 12, 2011 10:06 am
Looks good!
To optimize the redrawing a bit you can change the Redraw primitive to a Redraw Area to make the redraw area as small as possible. Also using a Float Changed can reduce triggers when triggers are sent without changing value.
compass_redraw_area.fsm
(32.4 KiB) Downloaded 1400 times
Morph
Postby fixstuff555 » Thu Oct 13, 2011 12:41 am
Well done.
I have to say that's one of the best looking graphic bitmaps I've seen on these forums.
fixstuff555
Postby horaceoz » Thu Dec 22, 2011 11:03 pm
good work on the compass
used this with the phidgets 3/3/3 for spatial info for my Land Rover
does anyone know how to use the 3 axis compass readings to allow pitch and roll compensation?
CarAttitudeMeter.fsm
Land Rover Attitude Meter
(63.9 KiB) Downloaded 1332 times
horaceoz
Postby Embedded » Fri Dec 23, 2011 12:30 am
Depends what it is your controlling. But it will involve using the PID module to give nice progressive results.
Embedded
Postby horaceoz » Fri Dec 23, 2011 12:39 am
At the mo I am using the yaw for compass heading for testing but I would like to use the compass data
horaceoz
