anyone know an optimized reverb?
if u know any optimized reverb on synthmaker or flowstone let me know or if u have one u wana share pls.
- djbrynte
Re: anyone know an optimized reverb?
This is what I have. Uses 30% CPU compared to the stock reverb.
FreeVerb_optimized.fsm- (19.4 KiB) Downloaded 906 times
Here is the version that uses MyCo optimized delay. Now reverb have 50% less CPU usage than Martins...
KG is Back has some insanely optimized delays, maybe some could try his...
FreeVerb_optimized MyCo Delay.fsm- (20.45 KiB) Downloaded 901 times
- Youlean
nice bro but martins effect is a reverb and yours is a delay
But thanx alot. You guys on Flostowne are the best! i mean i havent got this help somewhere else! BIG + to you guys!
SRY I SEE TRHIS IS REVERB TO! Nice done myco! maik:D
- djbrynte
Must say martins reverb used 2% lesser cpu
- djbrynte
is there an optimized delay aswell who use very very little cpu?
- djbrynte
you may try these delays: http://flowstone.guru/downloads/efficient-delays-and-delay-code-generators/
currently only integer-length delays are supported, but interpolated versions are being worked on. I may finish them tomorrow and post them, if you're interested.
Hi KG,
Always interesting in your posting, be it code or discussion.
THANKS !
THANKS !
thnx will try those. But do i just put the asm code inside the stock delay?
- djbrynte
Users browsing this forum: No registered users and 43 guests
