anyone here who knows how to set up moog octaves correct?
Im trying to figure out how i set this moog octave up. can some one help me pls. ALso the fine tune or semi.
Octave 32 16 8 4 2
Fine or semi -7 -5 -3 -1 1 3 5 7. i think this works like a fine tune on moog. Its not sued in steps.
Octave 32 16 8 4 2
- djbrynte
Re: anyone here who knows how to set up moog octaves correct
I don't know what MOOG you speak of, but the octave numbers you posted USUALLY refer to LENGTH in FEET. [crazy as that seems]. If this is the issue, the terms come from pipe organ tube lengths [generally speaking].
8 feet is usually taken as standard pitch, so to mimic the full range of a piano with a three octave keyboard you need to be able to raise and lower it by 2 octaves.
Yes the -7 to +7 is semitones non stepped tuning, if its the minimoog you want to imitate
- Xtinct
i fixed the octaves.
But Semi tones. Do you just mena to set the knob to -7 and to +7 with no steps?
- djbrynte
Anyway. The knob called MOD MIX on knobs what does it do?
- djbrynte
A quick search and
https://archive.org/stream/synthmanual- ... 0/mode/2up
All you need to know
Or play around with these
http://blog.wavosaur.com/best-free-vst- ... emulation/
- Xtinct
thnx i will test this synth.
- djbrynte
Users browsing this forum: No registered users and 44 guests
