It looks simple.
It looks simple.
Postby Parki » Sun Mar 01, 2015 2:56 pm
It looks simple: A is integer, when A is changed(time intervals undefined) the code returns different between the new value and the old.
Could anyone solve this problem?
Because I already four day can't solve this.
I hope my english was understeandable.
Skype id - parkidesu
Parki
Re: It looks simple.
Postby KG_is_back » Sun Mar 01, 2015 3:20 pm
This should work...
use the "sample and hold" prim. Calculate the difference between it's output and the input and hit sample and hold to update its value.
green diferentiator.fsm
(256 Bytes) Downloaded 792 times
Postby Parki » Sun Mar 08, 2015 2:18 pm
But it's don't work.
Parki
Postby KG_is_back » Sun Mar 08, 2015 4:03 pm
try this...
(290 Bytes) Downloaded 796 times
Postby Parki » Mon Mar 09, 2015 6:30 am
Why does it happens to me?
green diferentiator module problem.fsm
(1.71 KiB) Downloaded 808 times
Parki
Postby Youlean » Mon Mar 09, 2015 10:01 am
Will this work?
(348 Bytes) Downloaded 773 times
Youlean
Postby Xtinct » Mon Mar 09, 2015 11:04 am
Parki wrote:Why does it happens to me?
Check link /trigger order
Xtinct
